Author Topic: keyboard multimedia keys dont work correctly  (Read 3228 times)
slimpyman
So i press the Next track on my keyboard, and if Musicbee is not in focus, it seems to work perfectly fine.   However if Musicbee is currently in focus, it will cycle between the first track highlighted in the library, and the first track listed in the now playing list.
is this intended behavior?
slimpyman
So i am still having this problem, however now, whatevers in the now playing list it will just go between the top 2 in the list. in program or out of program the global keys  Fast forward or Back just rotate between the two.
when i let it just finish the song, without intervention, it will still just alternate between the 2.
I believe the new version may have botched the playback, cause I never had this problem before i updated.
this is the keyboard keys, the actual player buttons on the interface as well.  it will not cycle the whole playlist, just the top 2
Last Edit: December 05, 2014, 06:49:09 PM by slimpyman
it sounds like you have "playback follows cursor" enabled in the Now Playing preferences - if so, do you understand what it does?
slimpyman
I understand it now... i thought it refered to the playback position >_<
