The problem is that that's not a playlist, it's your main library. You can't reorder tracks in the library, they're just in whatever sort order you've given them. You can reorder tracks in the Now Playing List (i.e. play queue) or in the playlist node (which should be visible in the left sidebar, unless you've disabled it).
