Author Topic: UPnP/ DLNA device support  (Read 306055 times)
lodiped
I'm using this with ChromeCast and for some reason the songs always cut off a second in the beginning and another at the end. It's really annoying and I can't find anyone with the same problem. What settings could be impacting this?
zehuti
First of all - thank you for very good media player and DLNA plugin! I tried a lot of media players and MB is the best imo. 👍
But... there is that but with bugs 😁
Not sure if its MB or plugin related.
Over time in "Output to" new lines with same DLNA player is added. Even if MB is idling without anything playing. In DLNA plugin server and play to is enabled.
When MB is set Output to DLNA player. Choosing song on the phone from MB Media Library, file streamed as PCM. But if MB is set Output to Primary Sound Driver. Then file streamed as is - FLAC M4A MP3...
Playing to DLNA player from MB is always in PCM 44.1 kHz / 16 bit no matter what is set in settings.
MB version 3.3.7252
UPnP/ DLNA plugin from  25.06.2019
some lines from log
5; 1 Initialise - 09.11.2019 23:33:34
106; 2 GetNetworkAddresses - 192.168.2.1,dns=True,name=Wi-Fi,speed=300000000
117; 3 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
127; 4 GetNetworkAddresses - http://192.168.2.1:21038
178; 5 ProcessMessage 192.168.2.43 - device 'uuid:4e85d473-636b-1031-0080-0005cdca56be:ACT-Denon AVR-X1400H',valid=True
1585; 6 Profile - DENON, useragent=LINUX UPnP/1.0 Denon-Heos/147202
11120; 7 Profile - DENON, useragent=Shares User defined folders and files to other Universal Plug and Play media devices.|LINUX UPnP/1.0 Denon-Heos/147202
11131; 8 Profile - DENON, useragent=Shares User defined folders and files to other Universal Plug and Play media devices.|LINUX UPnP/1.0 Denon-Heos/147202
11168; 9 Activate - ACT-Denon AVR-X1400H:
11903; 10 Profile - Generic Device, useragent=libcurl-agent/1.0
11920; 11 ProcessRequest:HttpException:404 - Bad parameter
17842; 12 Play - D:\Music\flac\Simply Red - Greatest Hits (1996)\01. Simply Red - Holding Back the Years.flac (http://192.168.2.1:21038/encode/053C8DBDF4AF1361-2147483643.L16)
17893; 13 Profile - Generic Device, useragent=AvegaMediaServer/2.0 Linux/2.6
17956; 14 Profile - Generic Device, useragent=AvegaMediaServer/2.0 Linux/2.6
17967; 15 GetEncodedFile[1] 192.168.2.1 - GET D:\Music\flac\Simply Red - Greatest Hits (1996)\01. Simply Red - Holding Back the Years.flac to 192.168.2.43; mime=audio/L16;rate=44100;channels=2,rate=44100,channels=2
18509; 16 StateTimer - Playing,old=Loading
18957; 17 Profile - Generic Device, useragent=libcurl-agent/1.0
42694; 18 ProcessMessage 192.168.2.43 - device 'uuid:4e85d473-636b-1031-0080-0005cdca56be:ACT-Denon AVR-X1400H',valid=True
42798; 19 ProcessMessage 192.168.2.43 - device 'uuid:4e85d473-636b-1031-0080-0005cdca56be:ACT-Denon AVR-X1400H',valid=True
52193; 20 Profile - DENON, useragent=LINUX UPnP/1.0 Denon-Heos/147202
52220; 21 Browse - 0,BrowseDirectChildren,0,20,sort=
102691; 22 ProcessMessage 192.168.2.43 - device 'uuid:4e85d473-636b-1031-0080-0005cdca56be:ACT-Denon AVR-X1400H',valid=True
102795; 23 ProcessMessage 192.168.2.43 - device 'uuid:4e85d473-636b-1031-0080-0005cdca56be:ACT-Denon AVR-X1400H',valid=True
162691; 24 ProcessMessage 192.168.2.43 - device 'uuid:4e85d473-636b-1031-0080-0005cdca56be:ACT-Denon AVR-X1400H',valid=True
162793; 25 ProcessMessage 192.168.2.43 - device 'uuid:4e85d473-636b-1031-0080-0005cdca56be:ACT-Denon AVR-X1400H',valid=True
Last Edit: November 09, 2019, 10:40:28 PM by zehuti
are you willing to run a debug version of the plugin?
zehuti
Sure! I will gladly help to make it better. Just tell me what and how to.
I wont be able to do anything for a couple of days, however I already had made a couple of changes, so could you re-download the link from the first post to see if it helps. Make sure MB is closed when you replace the plugin dll
zehuti
Still the same. New lines with DLNA player is added even if i just open MB and AVR is just idling. Also tried with clean MB portable.
https://www.mediafire.com/file/o0l3nt3itit21xl/mb_Upnp.dll/file
replace the existing plugin making sure MB is closed at the time
I need the entry in the log for "NewMediaRendererDevice:"
zehuti
log file
zehuti
I think this should fix the multiple output devices issue
http://www.mediafire.com/file/4vvpxv0m4fs0vb6/mb_Upnp.zip/file
yes! no more multiple output devices 👍 👏
What about transcoding when streaming from MB to receiver? It always sends PCM stream. But it does not happen if i use app on the phone, connect to MB upnp server and tell what song to play.
zehuti
Found some other bugs.
Name of receiver in "Output to" changes. I cant figure out when and why it happens. It does not change when MB is already running. Name than MB gets at start stays the same.
First time i used new upnp.dll name was Denon AVR-X1400H.
After playing music for some time, closed MB and turned AVR off. And later opened MB and AVR on. Name was ACT-Denon AVR-X1400H.
I  was able to get name Denon AVR-X1400H ones again after closing MB and resetting AVR. But could not reproduce that again. ¯\_(ツ)_/¯
Also if i turn AVR off but MB is still on, name of the AVR is still in "Output to". And if i change "Output to" primary sound and then try to set back to AVR, MB then stops responding for 10-15 sec.
its probably best you use another application as i wont be able to help further. For the device name issue, i have made a change which is available on the plugin download link
Last Edit: November 16, 2019, 06:20:42 PM by Steven
Ralf
Strange thing. Installed the last release of MB and UPnP doesn't play anymore. Tried to switch to Continous Stream but no change.
The logfile mentions my Virtualbox network-adapter-IP in context with "streaming" instead of the physical network. Maybe that's a clue?
87111; 1 Profile - Generic Device, useragent=AVM UPnP/1.0 Client 1.0
88158; 2 Profile - Generic Device, useragent=FSL DLNADOC/1.50 UPnP Stack/1.0
88185; 3 Profile - Generic Device, useragent=Linux/4.4.59+, UPnP/1.0, Portable SDK for UPnP devices/1.6.21
106752; 4 Profile - Generic Device, useragent=|POSIX, UPnP/1.0, Intel MicroStack/1.0.2777
106758; 5 Profile - Generic Device, useragent=|POSIX, UPnP/1.0, Intel MicroStack/1.0.2777
107066; 6 Activate - Connect 150 00226124c770:http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:*,http-get:*:audio/mp4:*,http-get:*:audio/m4a:*,http-get:*:audio/x-m4a:*,http-get:*:audio/m4b:*,http-get:*:audio/x-m4b:*,http-get:*:audio/x-aac:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/L16:*,http-get:*:audio/L16;rate=11000;channels=1:*,http-get:*:audio/L16;rate=11000;channels=2:*,http-get:*:audio/L16;rate=11025;channels=1:*,http-get:*:audio/L16;rate=11025;channels=2:*,http-get:*:audio/L16;rate=22000;channels=1:*,http-get:*:audio/L16;rate=22000;channels=2:*,http-get:*:audio/L16;rate=22050;channels=1:*,http-get:*:audio/L16;rate=22050;channels=2:*,http-get:*:audio/L16;rate=44100;channels=4:*,http-get:*:audio/L16;rate=44100;channels=6:*,http-get:*:audio/L16;rate=44100;channels=8:*,http-get:*:audio/L16;rate=8000;channels=1:*,http-get:*:audio/L16;rate=8000;channels=2:*,http-get:*:audio/L8:*,http-get:*:audio/L8;rate=11000;channels=1:*,http-get:*:audio/L8;rate=11000;channels=2:*,http-get:*:audio/L8;rate=11025;channels=1:*,http-get:*:audio/L8;rate=11025;channels=2:*,http-get:*:audio/L8;rate=22000;channels=1:*,http-get:*:audio/L8;rate=22000;channels=2:*,http-get:*:audio/L8;rate=22050;channels=1:*,http-get:*:audio/L8;rate=22050;channels=2:*,http-get:*:audio/L8;rate=44100;channels=1:*,http-get:*:audio/L8;rate=44100;channels=2:*,http-get:*:audio/L8;rate=48000;channels=1:*,http-get:*:audio/L8;rate=48000;channels=2:*,http-get:*:audio/L8;rate=8000;channels=1:*,http-get:*:audio/L8;rate=8000;channels=2:*
185223; 7 Profile - Generic Device, useragent=AVM UPnP/1.0 Client 1.0
186463; 8 Profile - Generic Device, useragent=FSL DLNADOC/1.50 UPnP Stack/1.0
186477; 9 Profile - Generic Device, useragent=Linux/4.4.59+, UPnP/1.0, Portable SDK for UPnP devices/1.6.21
188839; 10 Play - stream (http://192.168.56.1:49382/encode/continuousstream-2147483633.L16)
I am not aware of any changes i made to the playback on the musicbee side. If you re-install the older MB version (which version was it?) does it work again?
Ralf
UPDATE with Workaround
I found a workaround on a german tech site which prioritizes the adapters and gives the phyiscal one the highest priority.
Hi Steven,
don't think it's a new problem, more a coincidence.
I could track the issue down: When disabling the Virtualbox-Ethernet adapter MB is doin what it should.
I assume the problem is how MB is choosing between multiple adapters and that it's always using the first one, which is VM in my case.
If I'm correct, is there a switch for this or do you have to correct the algo here? I don't even know wether there's any distinction technically between virtual and physical adapters.
See the log here for details. First start was with Virtualbox-adapter deactivated, on the second run it was on:
1; 1 Initialise - 26.11.2019 13:59:21
22; 2 GetNetworkAddresses - 192.168.251.27,dns=True,name=Ethernet 2,speed=1000000000
26; 3 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
30; 4 GetNetworkAddresses - http://192.168.251.27:49382
79; 5 ProcessMessage 192.168.251.22 - device 'uuid:3dcc7100-f76c-11dd-87af-00226124c770:Connect 150 00226124c770',valid=True
11700; 6 Profile - Generic Device, useragent=|POSIX, UPnP/1.0, Intel MicroStack/1.0.2777
11709; 7 Profile - Generic Device, useragent=|POSIX, UPnP/1.0, Intel MicroStack/1.0.2777
11976; 8 Activate - Connect 150 00226124c770:http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:*,http-get:*:audio/mp4:*,http-get:*:audio/m4a:*,http-get:*:audio/x-m4a:*,http-get:*:audio/m4b:*,http-get:*:audio/x-m4b:*,http-get:*:audio/x-aac:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/L16:*,http-get:*:audio/L16;rate=11000;channels=1:*,http-get:*:audio/L16;rate=11000;channels=2:*,http-get:*:audio/L16;rate=11025;channels=1:*,http-get:*:audio/L16;rate=11025;channels=2:*,http-get:*:audio/L16;rate=22000;channels=1:*,http-get:*:audio/L16;rate=22000;channels=2:*,http-get:*:audio/L16;rate=22050;channels=1:*,http-get:*:audio/L16;rate=22050;channels=2:*,http-get:*:audio/L16;rate=44100;channels=4:*,http-get:*:audio/L16;rate=44100;channels=6:*,http-get:*:audio/L16;rate=44100;channels=8:*,http-get:*:audio/L16;rate=8000;channels=1:*,http-get:*:audio/L16;rate=8000;channels=2:*,http-get:*:audio/L8:*,http-get:*:audio/L8;rate=11000;channels=1:*,http-get:*:audio/L8;rate=11000;channels=2:*,http-get:*:audio/L8;rate=11025;channels=1:*,http-get:*:audio/L8;rate=11025;channels=2:*,http-get:*:audio/L8;rate=22000;channels=1:*,http-get:*:audio/L8;rate=22000;channels=2:*,http-get:*:audio/L8;rate=22050;channels=1:*,http-get:*:audio/L8;rate=22050;channels=2:*,http-get:*:audio/L8;rate=44100;channels=1:*,http-get:*:audio/L8;rate=44100;channels=2:*,http-get:*:audio/L8;rate=48000;channels=1:*,http-get:*:audio/L8;rate=48000;channels=2:*,http-get:*:audio/L8;rate=8000;channels=1:*,http-get:*:audio/L8;rate=8000;channels=2:*
126143; 9 ProcessMessage 192.168.251.22 - device 'uuid:3dcc7100-f76c-11dd-87af-00226124c770:Connect 150 00226124c770' disconnected
126670; 10 ProcessMessage 192.168.251.22 - device 'uuid:3dcc7100-f76c-11dd-87af-00226124c770:Connect 150 00226124c770',valid=True
126677; 11 Profile - Generic Device, useragent=|POSIX, UPnP/1.0, Intel MicroStack/1.0.2777
126684; 12 Profile - Generic Device, useragent=|POSIX, UPnP/1.0, Intel MicroStack/1.0.2777
127370; 13 Activate - Connect 150 00226124c770:http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:*,http-get:*:audio/mp4:*,http-get:*:audio/m4a:*,http-get:*:audio/x-m4a:*,http-get:*:audio/m4b:*,http-get:*:audio/x-m4b:*,http-get:*:audio/x-aac:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/L16:*,http-get:*:audio/L16;rate=11000;channels=1:*,http-get:*:audio/L16;rate=11000;channels=2:*,http-get:*:audio/L16;rate=11025;channels=1:*,http-get:*:audio/L16;rate=11025;channels=2:*,http-get:*:audio/L16;rate=22000;channels=1:*,http-get:*:audio/L16;rate=22000;channels=2:*,http-get:*:audio/L16;rate=22050;channels=1:*,http-get:*:audio/L16;rate=22050;channels=2:*,http-get:*:audio/L16;rate=44100;channels=4:*,http-get:*:audio/L16;rate=44100;channels=6:*,http-get:*:audio/L16;rate=44100;channels=8:*,http-get:*:audio/L16;rate=8000;channels=1:*,http-get:*:audio/L16;rate=8000;channels=2:*,http-get:*:audio/L8:*,http-get:*:audio/L8;rate=11000;channels=1:*,http-get:*:audio/L8;rate=11000;channels=2:*,http-get:*:audio/L8;rate=11025;channels=1:*,http-get:*:audio/L8;rate=11025;channels=2:*,http-get:*:audio/L8;rate=22000;channels=1:*,http-get:*:audio/L8;rate=22000;channels=2:*,http-get:*:audio/L8;rate=22050;channels=1:*,http-get:*:audio/L8;rate=22050;channels=2:*,http-get:*:audio/L8;rate=44100;channels=1:*,http-get:*:audio/L8;rate=44100;channels=2:*,http-get:*:audio/L8;rate=48000;channels=1:*,http-get:*:audio/L8;rate=48000;channels=2:*,http-get:*:audio/L8;rate=8000;channels=1:*,http-get:*:audio/L8;rate=8000;channels=2:*
150778; 14 Activate - Connect 150 00226124c770:http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:*,http-get:*:audio/mp4:*,http-get:*:audio/m4a:*,http-get:*:audio/x-m4a:*,http-get:*:audio/m4b:*,http-get:*:audio/x-m4b:*,http-get:*:audio/x-aac:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/L16:*,http-get:*:audio/L16;rate=11000;channels=1:*,http-get:*:audio/L16;rate=11000;channels=2:*,http-get:*:audio/L16;rate=11025;channels=1:*,http-get:*:audio/L16;rate=11025;channels=2:*,http-get:*:audio/L16;rate=22000;channels=1:*,http-get:*:audio/L16;rate=22000;channels=2:*,http-get:*:audio/L16;rate=22050;channels=1:*,http-get:*:audio/L16;rate=22050;channels=2:*,http-get:*:audio/L16;rate=44100;channels=4:*,http-get:*:audio/L16;rate=44100;channels=6:*,http-get:*:audio/L16;rate=44100;channels=8:*,http-get:*:audio/L16;rate=8000;channels=1:*,http-get:*:audio/L16;rate=8000;channels=2:*,http-get:*:audio/L8:*,http-get:*:audio/L8;rate=11000;channels=1:*,http-get:*:audio/L8;rate=11000;channels=2:*,http-get:*:audio/L8;rate=11025;channels=1:*,http-get:*:audio/L8;rate=11025;channels=2:*,http-get:*:audio/L8;rate=22000;channels=1:*,http-get:*:audio/L8;rate=22000;channels=2:*,http-get:*:audio/L8;rate=22050;channels=1:*,http-get:*:audio/L8;rate=22050;channels=2:*,http-get:*:audio/L8;rate=44100;channels=1:*,http-get:*:audio/L8;rate=44100;channels=2:*,http-get:*:audio/L8;rate=48000;channels=1:*,http-get:*:audio/L8;rate=48000;channels=2:*,http-get:*:audio/L8;rate=8000;channels=1:*,http-get:*:audio/L8;rate=8000;channels=2:*
2; 1 Initialise - 26.11.2019 14:02:36
27; 3 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
33; 4 GetNetworkAddresses - http://192.168.251.27:49382
82; 5 ProcessMessage 192.168.251.22 - device 'uuid:3dcc7100-f76c-11dd-87af-00226124c770:Connect 150 00226124c770',valid=True
91; 6 Profile - Generic Device, useragent=|POSIX, UPnP/1.0, Intel MicroStack/1.0.2777
95; 7 Profile - Generic Device, useragent=|POSIX, UPnP/1.0, Intel MicroStack/1.0.2777
401; 8 Activate - Connect 150 00226124c770:http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:*,http-get:*:audio/mp4:*,http-get:*:audio/m4a:*,http-get:*:audio/x-m4a:*,http-get:*:audio/m4b:*,http-get:*:audio/x-m4b:*,http-get:*:audio/x-aac:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/L16:*,http-get:*:audio/L16;rate=11000;channels=1:*,http-get:*:audio/L16;rate=11000;channels=2:*,http-get:*:audio/L16;rate=11025;channels=1:*,http-get:*:audio/L16;rate=11025;channels=2:*,http-get:*:audio/L16;rate=22000;channels=1:*,http-get:*:audio/L16;rate=22000;channels=2:*,http-get:*:audio/L16;rate=22050;channels=1:*,http-get:*:audio/L16;rate=22050;channels=2:*,http-get:*:audio/L16;rate=44100;channels=4:*,http-get:*:audio/L16;rate=44100;channels=6:*,http-get:*:audio/L16;rate=44100;channels=8:*,http-get:*:audio/L16;rate=8000;channels=1:*,http-get:*:audio/L16;rate=8000;channels=2:*,http-get:*:audio/L8:*,http-get:*:audio/L8;rate=11000;channels=1:*,http-get:*:audio/L8;rate=11000;channels=2:*,http-get:*:audio/L8;rate=11025;channels=1:*,http-get:*:audio/L8;rate=11025;channels=2:*,http-get:*:audio/L8;rate=22000;channels=1:*,http-get:*:audio/L8;rate=22000;channels=2:*,http-get:*:audio/L8;rate=22050;channels=1:*,http-get:*:audio/L8;rate=22050;channels=2:*,http-get:*:audio/L8;rate=44100;channels=1:*,http-get:*:audio/L8;rate=44100;channels=2:*,http-get:*:audio/L8;rate=48000;channels=1:*,http-get:*:audio/L8;rate=48000;channels=2:*,http-get:*:audio/L8;rate=8000;channels=1:*,http-get:*:audio/L8;rate=8000;channels=2:*
2460; 9 Play - \\thelair\music\Boston\Boston (1976)\04 Rock & Roll Band - Boston.flac (http://192.168.251.27:49382/files/DACD27205673B306p.x-flac)
2510; 10 Profile - Generic Device, useragent=NSPlayer/8.0.0.3801
2721; 11 GetFile[1] 192.168.251.27 - HEAD \\thelair\music\Boston\Boston (1976)\04 Rock & Roll Band - Boston.flac to 192.168.251.22
2877; 12 Profile - Generic Device, useragent=FSL IR/0.1
3014; 13 Profile - Generic Device, useragent=NSPlayer/8.0.0.3801
3019; 14 GetFile[2] 192.168.251.27 - HEAD \\thelair\music\Boston\Boston (1976)\04 Rock & Roll Band - Boston.flac to 192.168.251.22
3051; 15 Profile - Generic Device, useragent=NSPlayer/8.0.0.3801
3056; 16 GetFile[3] 192.168.251.27 - GET \\thelair\music\Boston\Boston (1976)\04 Rock & Roll Band - Boston.flac to 192.168.251.22
3067; 17 GetFile - range=bytes 0-22463306/22463307
3413; 18 StateTimer - Loading,old=Stopped
3568; 19 Profile - Generic Device, useragent=FSL IR/0.1
3767; 20 Profile - Generic Device, useragent=FSL IR/0.1
3925; 21 StateTimer - Playing,old=Loading
3949; 22 Profile - Generic Device, useragent=FSL IR/0.1
91050; 894 Profile - Generic Device, useragent=FSL IR/0.1
91106; 895 GetFile[3] - exit=10054, playtime=88035
91226; 896 Profile - Generic Device, useragent=FSL IR/0.1
2; 1 Initialise - 26.11.2019 14:05:12
30; 2 GetNetworkAddresses - 192.168.56.1,dns=True,name=Ethernet,speed=1000000000
36; 3 GetNetworkAddresses - 192.168.251.27,dns=True,name=Ethernet 2,speed=1000000000
40; 4 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
45; 5 GetNetworkAddresses - http://192.168.56.1:49382
104; 6 ProcessMessage 192.168.251.22 - device 'uuid:3dcc7100-f76c-11dd-87af-00226124c770:Connect 150 00226124c770',valid=True
113; 7 Profile - Generic Device, useragent=|POSIX, UPnP/1.0, Intel MicroStack/1.0.2777
118; 8 Profile - Generic Device, useragent=|POSIX, UPnP/1.0, Intel MicroStack/1.0.2777
402; 9 Activate - Connect 150 00226124c770:http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:*,http-get:*:audio/mp4:*,http-get:*:audio/m4a:*,http-get:*:audio/x-m4a:*,http-get:*:audio/m4b:*,http-get:*:audio/x-m4b:*,http-get:*:audio/x-aac:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/L16:*,http-get:*:audio/L16;rate=11000;channels=1:*,http-get:*:audio/L16;rate=11000;channels=2:*,http-get:*:audio/L16;rate=11025;channels=1:*,http-get:*:audio/L16;rate=11025;channels=2:*,http-get:*:audio/L16;rate=22000;channels=1:*,http-get:*:audio/L16;rate=22000;channels=2:*,http-get:*:audio/L16;rate=22050;channels=1:*,http-get:*:audio/L16;rate=22050;channels=2:*,http-get:*:audio/L16;rate=44100;channels=4:*,http-get:*:audio/L16;rate=44100;channels=6:*,http-get:*:audio/L16;rate=44100;channels=8:*,http-get:*:audio/L16;rate=8000;channels=1:*,http-get:*:audio/L16;rate=8000;channels=2:*,http-get:*:audio/L8:*,http-get:*:audio/L8;rate=11000;channels=1:*,http-get:*:audio/L8;rate=11000;channels=2:*,http-get:*:audio/L8;rate=11025;channels=1:*,http-get:*:audio/L8;rate=11025;channels=2:*,http-get:*:audio/L8;rate=22000;channels=1:*,http-get:*:audio/L8;rate=22000;channels=2:*,http-get:*:audio/L8;rate=22050;channels=1:*,http-get:*:audio/L8;rate=22050;channels=2:*,http-get:*:audio/L8;rate=44100;channels=1:*,http-get:*:audio/L8;rate=44100;channels=2:*,http-get:*:audio/L8;rate=48000;channels=1:*,http-get:*:audio/L8;rate=48000;channels=2:*,http-get:*:audio/L8;rate=8000;channels=1:*,http-get:*:audio/L8;rate=8000;channels=2:*
631; 10 Profile - Generic Device, useragent=FSL IR/0.1
637; 11 ProcessRequest:HttpException:404 - Bad parameter
2111; 12 Play - \\thelair\music\Boston\Boston (1976)\04 Rock & Roll Band - Boston.flac (http://192.168.56.1:49382/files/DACD27205673B306p.x-flac)
Last Edit: December 10, 2019, 10:27:22 AM by Ralf
