Author Topic: Playlists won't sync into Sony Walkman  (Read 4358 times)
catchthewind
I can sync my songs from MusicBee into my Sony Walkman, but not the playlists.  Is there a setting I can change so that I can get the playlists into the Walkman?
TaRaNTuLa
To configure MusicBee to be able to sync playlists to your Sony NW-A35 Walkman: Select edit preferences\devices\Walkman\configure\settings
Leave everything to default except: Music Files: Music\<Playlist><Artist><Title> (You can arrange this to your liking but don't omit the arrow characters)
Storage Path: F:\ Make sure, use naming template, is checked
Playlists Path: MUSIC\
Check the box for: Create a subfolder for each playlist and its tracks.
Save as M3U
Now MusicBee will recognize the Sony Walkman. To send a playlist, created in MusicBee, to the Walkman, right click the playlist and select send to device WALKMAN. To configure Musicbee for an SD card installed on the Sony NW-A35, simply choose the settings for the SD card and make sure they are exactly the same. Now you have to go into the SD CARD folder in windows, under WALKMAN, and place a "Playlists folder under the root (NOT UNDER "MUSIC", just in the same root folder as the "MUSIC" folder).
Make sure, when you are done in MusicBee, that you right click WALKMAN in the lower portion of MusicBee and select safely remove. That's it. Kiss MEDIAGO goodbye. ENJOY and you're welcome. If you want to configure MusicBee for any other device, no matter what it is, all you have to do is connect your device to the computer and look at the file structure. Note exactly where the playlist file is. For instance, on the Sony NW-A35 WALKMAN playlists are placed in the root folder of the device in a folder called MUSIC. Now you simply look for the line, playlists path, under your devices settings, as explained earlier in this post, and name the playlist folder with a backslash. So the Sony NW-A35 would be playlist path: MUSIC\ Don't forget to put the backslash in front of the folder name. Don't forget the other settings mention earlier in this post for MusicBee, and the other mentioned settings for whatever device you wish to use. If you are using a different device than a Sony, then the earlier mentioned settings that reference the Sony would obviously be altered to add the name of your device. The most important setting will be your playlist path in MusicBee settings. It must be spelled exactly as it appears on your computer. This will allow MusicBee absolute control over your device, and the ability to send MusicBee playlists to any device. Incidentally, MusicBee can also import playlists from iTunes if you want the songs and their respective order to stay the same. To import a playlist from ANY other program that uses M3U files as their playlist file, simply click file\playlists\import playlist. You will be given a browser window so make sure you know where your playlists are stored. If you made a playlist in itunes and changed the order of the songs, you can import that playlist with all the songs in their respective order and nothing changed by importing the playlist into MusicBee. MusicBee is simply awesome and to me, is simply the most awesome program for interacting with audio devices, hands down. Itunes ******, as well as MEDIAGO, and most other programs. I choose MusicBee, WINAMP, or Media Monkey. Cheers.
Last Edit: December 08, 2017, 11:39:16 PM by TaRaNTuLa
