Author Topic: Question on field columns-  (Read 1729 times)
usraek
I'm wondering if there's a way to make each tab have separate fields showing? For example, in the first tab I have an artist pane that scrolls, so I'd like to remove the artist column from the main pane. In the second tab I'd like to have the artist column showing, but when I enable it in the main pane it enables it again on the first tab. Am I missing a tick-box or is independent fields per tab something that isn't implemented?
Displayed fields are remembered for each node's each view. So, no. You need to use different views (including custom views) for each tab.
usraek
Oh man, /that's/ what those were for. Two seconds later and it's completely sorted. I'm not used to this much power!
Thanks a lot!
