Author Topic: Comet (iTunes 12 theme) (v2.0)  (Read 29251 times)
Alumni
Comet, version 2.0
A light theme based on the iTunes 12 interface.
It is a modification of Calcium METRO by mikebo.
Download Skin:
https://app.box.com/s/k7lgd6y33lqq3te5eq7x
Tips & Tricks:
For best results I recommend these settings...
Enable skin window borders.
Enable spectrum visualisation.
Enable toolbar icon color matching.
Disable fit artwork to panel size.
Display player controls in top pane.
Show menu in default location.
The font I use is "Linux Libertine".
http://www.linuxlibertine.org/index.php?id=1&L=1
Last Edit: February 01, 2015, 08:43:36 AM by Alumni
vpsaxman
Looks fantastic, thanks!
Will you be skinning the Mini Player's modern layout?
Alumni
Updated, thanks for reminding me.
vpsaxman
Thank you!
Why is i in beta by the way? Everything looks good to me so far.
Chaython
All it really needs is things to be shrunken
Album art on itunes is much smaller so is the header
Thanks
mini player doesn't look different than the above picture
can you update track information tab?
Last Edit: November 20, 2014, 03:15:02 PM by Chaython
The latest MusicBee patches.
Alumni
Thank you!
I'm still thinking about making small changes to the interface.
Thanks
Sorry but your post is confusing. What do you mean by "things need to be shunken", can you be more specific?
Album artwork has nothing to do with skins, that is a setting you can change in MusicBee.
The mini player was altered slightly to more resemble iTunes, but I can only edit the colors.
What about the track info tab needs to be updated?
Last Edit: November 20, 2014, 04:00:56 PM by Alumni
Chaython
from the rest of your message I assume there's nothing you can do about the things I was mentioning, sorry.
Everything in itunes 12's ui is much smaller.
it's also dumb, to see the controls in mini player it cuts off the song's name even though the icons are lower than the songs name text
Chaython
My windows corrupted[bad sata controller], when I reinstalled the scaling issues were fixed after reinstalling  and recreating my layout.
Alumni
Updated to version 1.2, lots of changes and improvements were made to the interface. Please let me know what you think.
Last Edit: December 01, 2014, 02:01:52 PM by Alumni
vpsaxman
The icons are a nice touch, thanks!
Quick question: the track details in the now playing panel seems to be set to some grey color. I've tried to change it in MB's settings to no avail. Is it something you set in your skin? It seems I'm not having the problem with other skins. Thanks.
Alumni
I'm not sure what you're referring to.
Edit: Oh ok now I understand.
Last Edit: December 02, 2014, 09:23:26 AM by Alumni
  • MB Version: 3.6.8849 P
I'd guess that vpsaxman is referring to the pale grey text in the RH panel (Track Details) - green square
also:
toolbar icon is hard to see
no AutoDJ icon
Alumni
also:
no AutoDJ icon
Thanks vpsaxman and Bee-liever for pointing out those bugs, they're fixed in the newest update.
Last Edit: December 02, 2014, 12:18:11 PM by Alumni
vpsaxman
also:
no AutoDJ icon
Fantastic! Thanks for fixing these so fast!
