Author Topic: playback follows cursor doesn't work allways  (Read 3188 times)
gsax
setting:
Now Playing: playback follows cursor
problem:
when the cursor is set to a next song AND the actual song will end in LESS THEN 4 seconds AND cursor is set to the desired song in this period (less then 4 seconds till the end): next song according cursorposition will NOT START.
btw: setting "remove silence to active or inactive doesnt solve the issue.
any idea? in live situations it can be very important to choose the next song in the very last moment of the actual playing song.
Last Edit: October 31, 2014, 09:22:11 AM by gsax
i know what will be causing this but wont be able to look at it for a week or so
i think its too much of a change to do an ideal solution so what i have done is to reduce the preload time for the next track to 1.5 seconds when "playback follows cursor" is enabled.
Its in the next v2.5 update which i will post later or on the weekend
