MusicBee probably handles large libraries better than most programs. There are people with libraries over 100,000 tracks. 20,000 won't be a problem.
Usually the problem you have described happens when one of the tracks you're trying to import is corrupt or not 100% compliant with the specifications for that codec. Try importing your 4,000 tracks in smaller lots until you can work out which one is causing MusicBee to get stuck.
