Author Topic: lock mode configuration options  (Read 1847 times)
cepilong
Hello!!
I would like to set some options in the lock mode. For example, you can create lists that add songs or add songs to existing playlists. I think that for the good management of the player in foreign hands, you should be allowed to enable certain options and set the limits of the lock mode.
I hope I explained.
Thank you very much!!
cepilong
And in that way, the rating could be locked too. It's easy change the rating of a song without intention...
Thanks again!!
