As the title says, I've two major issues regarding downloading podcasts. They are as follows:
1. When downloading the episodes for some podcasts, I am prevented from doing so, getting a "The request was aborted: Could not create SSL/TLS secure channel" error. An example of such a podacst is the "Anivsion.com" podcast if you need something to test with. I've had this issue for many months and can't work out how to fix it. Google isn't any help either.
2. When adding some podcast subscriptions, I find them removed upon restarting musicbee. The episodes are still in the folder, but the actual subscriptions are gone. Additionally, I always notice that there is a "subscription-corrupted" file in the podcast folder (usually larger than the "subscription" file that I guess houses the list of subscriptions. There is no telling which podcasts this will happen to, as it sometimes happens to podcasts I previously had no issue staying subscribed to.
Any idea on how I can fix these two issues and resume normal use of musicbee again? I've the latest version of musicbee if that means anything. I'm also running it on Window Home Premium.
