Author Topic: I turned something off, can't find how to turn it back on ...  (Read 2669 times)
ziffel
screenshot: http://i.imgur.com/UjKV5H1.jpg
About where that arrow is pointing, I had a bar with options of things like how to sort the displayed albums or songs. I've somehow turned that off, and can't find how to re-enable it. I don't know what it's called, but I've looked through every button/menu/list i could find.
It let me do things like sort the albums by artist, rating, etc.
thanks
Alumni
Are you talking about the "header bar" with "configure layout" options? That is located at the top right hand corner of the main panel, under the search bar. You can click it again to re-enable the header bar.
ziffel
Yes, that was it! Thanks very much.
