log:
29.10.2014 16:29:16 - base size={Width=1645, Height=45},scale=3,05194805194805,font=[Font: Name=Segoe UI, Size=16, Units=3, GdiCharSet=1, GdiVerticalFont=False],orig hscale=2,64155844155844
29.10.2014 16:29:16 - g size={Width=1645, Height=45},scale=3,05194805194805
29.10.2014 16:29:21 - before bounds={X=0,Y=0,Width=604,Height=634},main panel={X=6,Y=31,Width=592,Height=618},main tabs={X=121,Y=-10,Width=469,Height=588},radio right=562
29.10.2014 16:29:22 - after bounds={X=0,Y=0,Width=1602,Height=987},main panel={X=3,Y=3,Width=1590,Height=949},main tabs={X=320,Y=-29,Width=1239,Height=1302},radio right=1104
screenprint:
http://imageshack.com/a/img673/7485/Co40oZ.pngbetter this way?
important:
1.) as i use a dsp plugin called stereo tool 7.4. which has veeery small hardcoded fonts i have to set windows system fonts high = 150%
2.) i have to use my surface pro VERTICAL so, in vertical mode radiobuttons are much more cut then in horizontal mode.
3.) again: the solution of this issue would be to make the preferences and edit windows sizeable, same as the main window.
but perhaps this is not possible?
