here is the complete error log, including the debugged lines at the end:
as you can see, i used 3 different font sizes 13, 14, 16.
with font 16, shift-edit (mainpanel, titel) it looks like this:
http://imageshack.com/a/img538/9066/5O5iEQ.png as you see, field "settings" is nearly not visible anymore.
and btw: i need (!) this windows-dpi-size on my tablet, because there are som SW which have hardcoded characters (Stereo Tool 7.5 plugin)
again: i think, making windows sizeable (mouse/lower right corner/pull to bigger-smaller) will solve the problem in a elegant way ;-)
15.09.2014 22:15:58 - 6.2.9200.0 - 2.4.5349.24454 - System.IO.DirectoryNotFoundException: Ein Teil des Pfades "C:\Users\roland\Music\G-SAX LIB\NowPlaying.mbp" konnte nicht gefunden werden.
bei System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
bei System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
bei System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
bei #=qpcFOpixrLX66ZE8bzcqABol9FmRfcHakpn4B52pZZXb2zojnJRLhHF1gfhHxVEHA.#=qKVRrjOdQiUmqC_1xYfDz9g==(List`1 #=qRcTRjM107CQUOEZJ6dBkxw==)
bei #=qHljrdtP3I8_G_ZYn2eAsHZUeJB0yZSNBZqrfTVPUx_qlIju65eyy6wkIvFE8Zm2X.#=qzHaWzRxVEOdZMtnNvjEolg==.#=q5a0VAbWH8y4BIezFUrBVJwz5f5UfAelHj_Omk$EOVK4=(List`1 #=q_WJdXcjlcfSHbcKv3itw4A==)
bei #=qET5accnol4uDdy5UaVu19ItTZSPSKGN_zUJUhZiV89s=.#=qygNX9Pe_5vSkAYJ1$Ay6$g==()
bei #=qQKgQlzopBAX0JRe8LATELXDdHrQqotjB$ES4NrYICH0=.#=qqqr7w8hWXnH0aCveKFMcpoyCnqhwG76NH3MNVOcL9eM=(CloseReason #=qzG7xw3ds1g6Bzx9GgQbnFQ==)
15.09.2014 22:16:01 - 6.2.9200.0 - 2.4.5349.24454 - System.IO.DirectoryNotFoundException: Ein Teil des Pfades "C:\Users\roland\Music\G-SAX LIB\MusicBeeLibrarySettings.new" konnte nicht gefunden werden.
bei System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
bei System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
bei System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
bei System.IO.StreamWriter..ctor(String path)
bei #=qSC3aA$9658NPrbY4zi5M_LqAYtvo33VoLrsGwUog4D5IWU0pqMGO5Y3ki2cLo8oK..ctor(#=qIoOVuKwlbh5ChfLnyUVKtjWN_K_WyERMzi0DRhsgvyg= #=qhF6qF2M3RBs9Vl0Ikp8tKw==)
bei #=q4E42t1g3x8GR5g$edMWnPjBPp2zigsBDyM8GMHJ3VyI=.#=qsd1batvgdfzyvQpghzeSZA==.#=qlAWCmrBticqoYmnpBCp8mQ==()
15.09.2014 22:16:01 - 6.2.9200.0 - 2.4.5349.24454 - System.IO.FileNotFoundException: Die Datei "C:\Users\roland\Music\G-SAX LIB\MusicBeeLibrary.mbl" konnte nicht gefunden werden.
Dateiname: "C:\Users\roland\Music\G-SAX LIB\MusicBeeLibrary.mbl"
bei System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
bei #=qHljrdtP3I8_G_ZYn2eAsHZUeJB0yZSNBZqrfTVPUx_qlIju65eyy6wkIvFE8Zm2X.#=qz9a79N0S_DbUzHHcP$GKYEyK2WBtF15peXWc842J2X8=.#=qkddzDCPDNheDfZfLe7O1dQ==()
bei #=qHljrdtP3I8_G_ZYn2eAsHZUeJB0yZSNBZqrfTVPUx_qlIju65eyy6wkIvFE8Zm2X.#=qz9a79N0S_DbUzHHcP$GKYEyK2WBtF15peXWc842J2X8=.#=qCttj$osFGGZH$LaShRTD0g==()
bei #=q4E42t1g3x8GR5g$edMWnPjBPp2zigsBDyM8GMHJ3VyI=.#=qMk8uzbXabYouSZTfMyawUg==()
15.09.2014 23:46:31 - File open failed: 'D:\G-0815\01 Bb ANATOL.mp3' - Der Prozess kann nicht auf die Datei "D:\G-0815\01 Bb ANATOL.mp3" zugreifen, da sie von einem anderen Prozess verwendet wird.
16.09.2014 10:19:50 - 6.2.9200.0 - 2.4.5349.24454 - System.IO.IOException: Der Prozess kann nicht auf die Datei zugreifen, da sie bereits von einem anderen Prozess verwendet wird.
bei System.IO.Directory.InternalMove(String sourceDirName, String destDirName, Boolean checkHost)
bei #=qVReyYT97n4GeohQAyrCk4RWgANa1cqPVbTuqux5e3AkM5hPGu6cZa4r4eJxF_rPK.#=qAFTjYPxijiBiK1gsEtyMTQ==(#=qxZS1a2dGHxnHdyyLHXeiPgwHi9J34O93zV50UZ_g3fM= #=qUHohFbU4$H6nd5olgo3fTQ==, #=qxZS1a2dGHxnHdyyLHXeiPgwHi9J34O93zV50UZ_g3fM= #=qu4iHDhn$zltxzjSWN$5BRw==)
bei #=qVEGuv$CiewMQy5$XJdGTJeKVaZ$ordPmB71zH7GW72YMzfDtubox8Lf6TDZCTBwW.#=qD6_Ucvoee6TsD7vgMc2SBw==(#=qxZS1a2dGHxnHdyyLHXeiPgwHi9J34O93zV50UZ_g3fM= #=qa6Mm269Gaz9H5OU4DDOBhw==, #=qxZS1a2dGHxnHdyyLHXeiPgwHi9J34O93zV50UZ_g3fM= #=qhfCx8xe4R7HQg15mRVk9Vg==)
bei #=qHljrdtP3I8_G_ZYn2eAsHZUeJB0yZSNBZqrfTVPUx_qlIju65eyy6wkIvFE8Zm2X.#=qtSVmxICfSgjqmm66xfdsHg==(#=qxZS1a2dGHxnHdyyLHXeiPgwHi9J34O93zV50UZ_g3fM= #=q4S7gnNhemssk7QsCwkaCZg==, #=qxZS1a2dGHxnHdyyLHXeiPgwHi9J34O93zV50UZ_g3fM= #=qZ61GWlGIunW4dB5aqVmceg==)
bei #=q6eSbpRZB7_ughz9d01mFKz6qSn6seIPlKMqIjs7b1H4=.#=qzD5uAV3BbJIUoBJ_SbAza6ZLGz2AhsnfENjVJTSSJJQ=(#=qLxryLYvWyxxPNDhfYzq32bgQmmucLuX504O6qrVruzWERyFWk7T_jrbZt3vfUal0 #=qSrSD_1eVK4mPQ$gTQA760Q==, List`1 #=q72nwGEMrWyuIcsMvMKjkOA==, DragEventArgs #=qNaMj6tyRj1T1TYRKv2SjDw==, Boolean #=qyzkdMgcdC8q5PUbRqrLbjQ==)
16.09.2014 12:11:08 - 6.2.9200.0 - 2.4.5349.24454 - System.TypeInitializationException: Der Typeninitialisierer für "#=qkVkuL6neTD7TZkUzAEP_OQ==" hat eine Ausnahme verursacht. ---> System.ApplicationException: Unable to load 'C:\Users\roland\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\bass.dll'
bei #=qWsUFs$m6Zn9AMCandKZV5NYW$o5oK6oe3z1p5HeXqSc=.#=qWdxTxs$wzdqrcT3XKNJw0BM5KFC5l$naoIhNdNsRHUg=(String #=qXznN8Wt3ukPK4j63D_K4dQ==)
bei #=qkVkuL6neTD7TZkUzAEP_OQ==..cctor()
--- Ende der internen Ausnahmestapelüberwachung ---
bei #=qkVkuL6neTD7TZkUzAEP_OQ==.#=qsnt7pYFfYLR1jZFCFhSXmA==()
bei #=q6fBk33lUiVSZdlo2TwlAMZdl1bmuJgsxdB5jy3KnLLA=.#=q3oTYJYs9QFA9IH5_2de8Lw==(IntPtr #=qsQT3yJcFdnB8pdhn$eJiKg==, ISynchronizeInvoke #=qzzmIiErVlLDPC1E5QD1iVg==, Boolean #=qakXDhL0BD9SC0XFGdhzM2g==, List`1 #=q7a_Y1Ww9zArMirC4s9aShg==)
bei #=qET5accnol4uDdy5UaVu19ItTZSPSKGN_zUJUhZiV89s=.#=qcNiGbkDZHPRXKNgHlID6cSCTiaY6NduR16AQ9676uNI=(IntPtr #=qt2nMqcLEXVwvXnuQ05PpPw==)
bei #=qQKgQlzopBAX0JRe8LATELXDdHrQqotjB$ES4NrYICH0=..ctor(IList`1 #=qjjwI4J2Aqbx7TfodpXmuqA==)
bei #=qQKgQlzopBAX0JRe8LATELXDdHrQqotjB$ES4NrYICH0=.#=q5NFAE51a22HqcigyEUp7yV6Frs4O72nqscxUpQEMTm8=.OnStartup(StartupEventArgs #=qkrtqcBNnyqG74bXrTAMAxA==)
15.10.2014 15:01:38 - 6.2.9200.0 - 2.5.5401.12617 - System.TypeInitializationException: Der Typeninitialisierer für "#=qrPeInAhqH_hUNZNTsLpqFw==" hat eine Ausnahme verursacht. ---> System.ApplicationException: Unable to load 'C:\Users\roland\Downloads\MusicBeeDebug\bass.dll'
bei #=q7dxhd8Cl6pdV0SASBUbNoUVVKNkal2TrrOhr_rCJhQE=.#=qGiOi7bEVzh13oIPVCtj4ZoibGzzu5kpaQKuZ99Nueh4=(String #=qFGuixZLydL_IPlJJKnGtGw==)
bei #=qrPeInAhqH_hUNZNTsLpqFw==..cctor()
bei #=qrPeInAhqH_hUNZNTsLpqFw==.#=qOHRGG1$KlDfYze4qvWEY7Q==()
bei #=qnUybqz_67tOQ3e9O61OkjjnVBkZtUbpbcndo2Z6t7_Y=.#=qthKmueu3$srjN_kbPecyNA==(IntPtr #=q8CkVWjSqU5K0rGdRB2HQKA==, ISynchronizeInvoke #=q$wKrQVmPki2shjAE3afy8A==, Boolean #=qvqlnVhURVlseVrk3ClIWKA==, List`1 #=qT0bwrQx1UudjpNqFZkxHMw==)
bei #=qn2K_iTry0DEd8ik4zYvU2zMDWAKMfNa9EQLEYDUArrA=.#=q8qLxlwwPQfB0QD8Ziv0rpYkvv_c2JQil7B47soaMyNo=(IntPtr #=qGrMlZ6WVpEQHIN437uMPmQ==)
bei #=qyc3sRd0OO9uiAuTSHWCuaP2ZC1reJxLAdS3LVN_eYLA=..ctor(IList`1 #=qTkeLofSGcd4uHsFQ$rHJRw==)
bei #=qyc3sRd0OO9uiAuTSHWCuaP2ZC1reJxLAdS3LVN_eYLA=.#=qB2lg$srnmDJ2AUvkVVNwruR61ymmnzms1ihvPCf2DMM=.OnStartup(StartupEventArgs #=qkrtqcBNnyqG74bXrTAMAxA==)
15.10.2014 15:02:03 - 6.2.9200.0 - 2.5.5401.12617 - System.TypeInitializationException: Der Typeninitialisierer für "#=qrPeInAhqH_hUNZNTsLpqFw==" hat eine Ausnahme verursacht. ---> System.ApplicationException: Unable to load 'C:\Users\roland\Downloads\MusicBeeDebug\bass.dll'
15.10.2014 15:04:29 - 6.2.9200.0 - 2.5.5401.12617 - System.TypeInitializationException: Der Typeninitialisierer für "#=qrPeInAhqH_hUNZNTsLpqFw==" hat eine Ausnahme verursacht. ---> System.ApplicationException: Unable to load 'C:\Users\roland\Downloads\MusicBeeDebug\bass.dll'
15.10.2014 15:06:33 - dpi=144,scale=1,5,font=[Font: Name=Segoe UI, Size=13, Units=3, GdiCharSet=1, GdiVerticalFont=False],width=217
15.10.2014 15:07:22 - dpi=144,scale=1,5,font=[Font: Name=Segoe UI, Size=14, Units=3, GdiCharSet=1, GdiVerticalFont=False],width=232
15.10.2014 15:08:17 - dpi=144,scale=1,5,font=[Font: Name=Segoe UI, Size=16, Units=3, GdiCharSet=1, GdiVerticalFont=False],width=264
