Author Topic: Tags won't update properly  (Read 2171 times)
digital_ac3
Why won't the music library update the tags? I have changed the tags but it shows the same. I did a full rescan. But it didn't help. What seems to be the problem?
All of other entries above Queen suffer the same problem.
Pingaware
Are the files read-only? That does weird stuff.
digital_ac3
Hey sorry for the late reply. I was away for sometime. And nope. They are not read-only. I can make any changes to the files without problem. But the changes won't update in the artists column.
what is displayed before; exactly which field(s) you changed and the value you changed them to; and then what the final result is.
Does it happen with all fields, and does it happen with all files (using the same steps)
