I often listen podcasts which often are several hours long. It'd be rather important to continue playback where you left off. On startup options I've tried both "resume playback" and "resume position" with no success.
Quote from: Super Meat Boy on October 06, 2014, 12:05:12 AMI often listen podcasts which often are several hours long. It'd be rather important to continue playback where you left off. On startup options I've tried both "resume playback" and "resume position" with no success.You need to set "remember playback position" in the tag editor.http://musicbee.wikia.com/wiki/Tagging#Settings
