Author Topic: Disabling the "Extended View"  (Read 3862 times)
JirikDrak
Hi, I loved the old way the Artwork layout used to work very much. I want to just have an overview of the artists and then be able to show the Albums and Tracks on click-through. The new extended view replaced this and I totally hate it, it doesn't work well, if you have more than a few albums from the artist and there is no way to view tracks from more than one album at the same time.
Is there any way to disable the extended view and go back to the old way? I wasn't able to find it anywhere, so I had to go back to the previous version for now.
Pingaware
The short answer is yes, somewhere in the Layout section of preferences there's an option to disable it. But I don't have MB in front of me and so can't tell you exactly what the option is called.
It's in the "customize panel settings" dialog, which is found in the same menu as sort by/group by options.
Pingaware
Damn it. Knew I'd get it wrong without having MB to look at and check  :P
JirikDrak
