Author Topic: I love Musicbee but can't get Silverjuke look  (Read 3231 times)
mtech
Hi There
Apolgies for mentioning another product but...
I purchased Silverjuke a few years back thinking it was the best Media Player Ever. I love the Layout and I know MusicBee can do it, but I am clueless how to get it to look like that. Can anyone help. The Development of Silverjuke has stopped years ago and MusicBee blows it away in customisability and features and every other department.  I just can't get to grips with how to modify the look of MusicBee. ???
Can you give us a screenshot?
mtech
This is Silverjuke it has a great feel but zero developement
I also bought Helium-10 This doesn't perfrom as well as MB on big Libraries even though
it is closer but I love Musicbee.
I Also bought Winamp and a slew of others but always back to MB.
Ah.  You won't be able to replicate Silverjuke exactly, but if you start with one of cartman005's iTunes lookalikes (http://musicbee.wikia.com/wiki/Skins#cartman005) and use Artwork view (http://musicbee.wikia.com/wiki/Artwork_View) you can get a hybrid of your two screenshots.
Most layout options are in the Configure Layout Menu, which is to the left of the search box (unless you have tabs in the caption bar, in which case it's to the right of the tabs).
mtech
Thanks, I stumbled across what looked like the right setup but lost it somehow.
Will give your suggestions a bash.
silvestreccf
mtech
