I paid attention, that MB 2.4 doesn't check if podcasts have been synced already with the sam device.
I'll give an example, let say, I synced all my podcasts with device. Now I disconnected it and reconnected.
No new podcasts have been downloaded, I click again on the button «Sync» and MB begins syncing process again, since the connection is provided by MTP-protocol, which is very slow (comparing to copy & paste to regular USB 2.0 flash drive/SD-card) it may take a lot of time.
Is there any way to add the check if the same files are already on the device and if yes, to ask to overwrite them or just finish the syncing with status «no new files to sync», exactly like iTunes does.
Thanks.
