Author Topic: Search all fields plus URL(path). Is that possible.  (Read 2193 times)
kdrat
Hello,
is it somehow possible to search all fields AND URL/path?
Example: I want to search for all music in my library from year 2009. Some of the songs are in folder called "2009", but most of them are in different folders with year 2009 marked in id tags.
I know it is possible in custom search, but is it somehow possible in basic search field? Option "Search all fields including path" would do just fine.
Thank you for advice in advance.
Welcome to the forum!
Yes, see the FAQ: http://musicbee.wikia.com/wiki/FAQ#Can_I_search_using_file_name_and_location_rather_than_tags.3F
It will actually include both.
kdrat
Thank you for your response. However, FAQ say that I should tick +Filename. Problem is, I do not see anything like that. Can you please look at attached picture and tell me if I am blind
http://i62.tinypic.com/30xbo5h.png
EDIT: I have updated it to newest version and now it works :) T
Thank you!!
Last Edit: September 10, 2014, 07:24:08 PM by kdrat
