When I first tried to import my iTunes library by scanning my iTunes folder, only a few thousand songs (from artists starting with A and B) successfully imported. There was no indication of error during the scanning process, however the import was incomplete.
Next I tried "Import From Library>Import from iTunes" and selected my iTunes Library.xml. This time the rest of my library was imported but all the new songs did not have certain metadata such as play count and rating. So currently in my MusicBee library, only the songs from artists starting with A and B have play count and rating.
Are you sure you didn't try to import from iTunes Library.xml first, and then just scanned the files?
When you first create a MusicBee library, you have to designate the music folder you want to scan, right? I selected my iTunes
folder, not .xml file. The first time it only imported about 2000 songs.
I've just tried this process again with two new MusicBee libraries. This time all the songs were imported but strangely, a few hundred songs have ratings but none have play counts. I'm quite baffled.
I'm not sure if I messed up my initial import but I'm still stuck with basically the same problem—incomplete metadata—after creating two new libraries.
