Author Topic: Beginner Guide / Tutorial  (Read 39507 times)
Withein71
i think its something else...
automatic organizing doesnt work with musicbee properly. it didnt work with mediamonkey as well.
in windows explorer: when i want to delete, rename or move certain folders, windows tells me that these files/folders are in use...
but its not with every folder/files like that. i can delete/rename/move some of the files/folders without any problems... but other files/folders just won't move. only with unlocker software.
That's Windows permission/ownership issue with those files and folders. Until you fix the issue, any program won't work properly when needs to access those files and folders. Google the problem and you will find lots of guides and suggestions, or ask around in Windows forums for the solution.
Withein71
ok got it.
something different: how do i enable folder.jpg view?
you can consult the wiki and the pdf guide linked on the wiki homepage. Searching in the forum will answer most of your questions.
Withein71
ok, i found a lot of answers but there is still one thing i dont know where to find.
is there an automatic volume analysis? mediamonkey did all new mp3 files automaticly to 89db.
i only found this topic but its very old and no one answered:
http://getmusicbee.com/forum/index.php?topic=3375.0
Yes, you can tick "calculate and write missing replay gain tags for new music files" option under Preferences> Tags (2). Then MB will do volume analysis when new files are imported to library. But if new files are detected on start-up and moved straight to the library, then currently they miss volume analysis: http://getmusicbee.com/forum/index.php?topic=13515.0
Withein71
thanks.
and where can i customise the volume to 89db or is this the default adjustment?
Yes, I think that's the default target dB for RG2 as well. For more details, consult this thread: http://getmusicbee.com/forum/index.php?topic=10394.0
Withein71
hey, its me again.
i have a question, maybe a problem...
i selected at "tags (2)" -> automatic genre searching and tagging but musicbee does not search the genre on its own... :(
Withein71
got it. :)
Last Edit: September 17, 2014, 04:25:42 PM by Withein71
