Author Topic: Next button for searching through the Now Playing playlist  (Read 1816 times)
Cypher
Navigation through the Now Playing playlist isn't very pleasing. There isn't a way to go through the results of the search as it only selects the first result.
If you search though the Now Playing panel (you can do that by typing the search in the panel), you can cycle through the results with the "Next" button in the search bar itself. This button should also be in the search bar when searching the Now Playing playlist. There should be also a hotkey for that button if there isn't any.
This would searching through the Now Playing playlist much easier and people (and me) need to use the Now Playing assistant for the sole purpose for searching a song in it.
