here's what I an trying to to with MusicBee version 2.3:
1) The focus in on the left panel
2) In the left panel, using UP and DOWN arrow, I navigate to select a node (e.g. "Playlist \ Recently added").
3) When you navigate to a node, the corresponding albums show up in a tab.
4) I would now like to switch focus to the first album in that tab without using the mouse.
5) If the focus is on the tab, using UP, DOWN, LEFT, RIGHT you can then navigate to the appropriate album to start it playing using ALT+ENTER (or assigned hotkey)
Is there a way to switch focus from left panel node to an album in the corresponding tab (without mouse click)?
And switch focus back from a tab to the left panel?
