Author Topic: denied access to the musicbee library  (Read 1987 times)
anvienhponline
Hi
on startup i keep getting the message "You were denied access to the musicbee library".
Running as an admin did not help. The programme just won't start.
How can i fix this? Thx
Download a portable version and install it in a non-special folder. That would be easier than trying to fix the access issue, and you won't suffer from the same problem again.
