Author Topic: Ability to select multiple playlists and then delete them  (Read 3530 times)
quawa
Hello,
MB imported all .m3u playlists and a vast majority is auto-generated. Now when I want to delete them, I have to delete each seperately. Would be nice to be able to select multiple playlists and then delte them.
Great program!
for now just delete the .m3u from the Playlists folder where the musicbee library is set (by default the Music folder)
Also in later versions than you are using it no longer imports the playlists on the initial scan as a number people have had the same issue as you
