Author Topic: 'Smooth Grey' Skin  (Read 50455 times)
jackuars
so why is it not posted in the downloads category?
Rotem K.
The downloads forum is updated weekly every monday.
Since this Exe was compiled after monday last week it hasn't been posted yet.
Note that if you download this Exe [v1.2.3980], you should still check back tomorrow for the weekly one, as it will probably be an even fresher version.
Rotem K.
-----------Image-----------
- First .EXE to support [all the skin elements] v1.2.3990: http://www.mediafire.com/?9ud2j3x9a4l0a8a
- Skin File: http://www.mediafire.com/?cgx51jn5l5lg337
changes:
- in line menu.
- AutoDj screen.
- spectrum visualization colors.
- FM Love icons, in player and in mini mode.
- artwork view rating.
- tabs colors for lyrics and details.
- few more color changes.
A bounch of thanks as always to Steven.
Enjoy!
Rotem K.
Rotem K.
- Skin File: http://www.mediafire.com/?b730y3aunr0sqg7
version 1.2.4026 or higher is required: Downloads Post
Changed:
- Locked text box background an text colors
Last Edit: January 09, 2011, 08:40:39 PM by Rotem K.
Rotem K.
UPDATED LINK
Changes:
- New Splashscreen.
- New Top Border.
- Clean JPG's for Window Buttons.
- Mini-Player Now Playing list toggle button.
- Modified Text color [in edit screen] .
- Locked Text in locked Text Boxes.
- Love Icon in mini-player mode (mouseover and 'loved') .
- Menu.DropDown.Highlight BDR color.
Known Issues:
- Menu.DropDown.Highlight BDR color currently causing double borders in the Menu.ParentItem.Pressed.
  This either will be fixed in the next beta/EXE or if a fix is not possible, I'll take the BDR setting off.
Update: Menu.DropDown.Highlight BDR issue solved with the new EXE.
Last Edit: February 01, 2011, 09:41:08 PM by Rotem K.
Rotem K.
Rotem K.
UPDATED LINK
Changes:
- Embedded buttons
- A-Z jump panel
- Edit Screen Toolbar highlights
- Lighter body borders.
rotem i think its looking really professional and i think the new buttons work very well.
in the latest MB version i've fixed the close button for the a-z bar so its consistent with the toolbar letters and mouseover
antiPOP
Steven, thanks for the fix, but I think the same issue is on now playing popup
ksvane
Resurrecting this topic to give RotemK my thanks for this skin... it's my default, blends in perfectly with the grey color of my taskbar.
vpsaxman
Rotem K.
Updated link.
Changes:
- Fixed colors for the new TabsVBar - vertical tabs elements.
Ksvane and vpsaxman, Thanks for your feedback! I appreciate it.
Last Edit: November 09, 2011, 06:06:28 AM by Rotem K.
damiankrol
