Author Topic: Show track information "in panels using tabs" in Now Playing tab?  (Read 4021 times)
holuschi
I try to customize Now Playing Layout Configuration.  I choose "show track information" - "stack panels using tabs" and click save. But it does not save, it always switches to "show all panels vertically". I can save show track information" - "stack panels using tabs" in Playing Track tab but not in Now Playing tab. Is this a feature?
If you meant combining now playing list as another tab into the track info panel, then it's not possible.
holuschi
Thank you, redwing, for response. Here is the screenshot: I am in Now Playing Tab with open right hand tab - cutomize panel settings.
If I try to change "show all panals vertically" to "stack panels using tabs" (yellow)  it cannot be saved. But it can be saved if I am in the PlayingTrack tab
Yes, I can replicate the issue. If this was intentional, then I think it's another unnecessary restriction regarding the now playing panel layout.
(A while ago I reported some buggy issues related to the panel, but don't see much differences since then: http://getmusicbee.com/forum/index.php?topic=11333.0)
Anyway a workaround would be:
- Choose another tab.
- Open now playing config pane, turn off now playing list, and tick "stack panels using tabs".
- Click on now playing node in left navigator, then you will see the tabs remain on the sidebar even after restart.
holuschi
