Has anyone tried the AudioBurst FX output plugin with MusicBee? I imported it from Winamp and I think it gives a great sound, but gapless playback doesn't seem to be working properly in MusicBee. It actually skips the last little bit of a track every time the track changes, so if there is no silence between the tracks you can actually hear the previous track get cut off on a track change. I think it might be a buffering issue because when I decrease the buffer size in the AudioBurst settings to as low as it will go (0.5 seconds), less of the track gets cut off but you can still hear a slight hitch. This makes me think if I could put the buffer in AudioBurst at zero it would not get cut off at all, but that wouldn't really be ideal anyway. When I used it in Winamp it worked fine with the default 2 second buffer.
Anyway, I was just curious if anyone else had tried it or if anyone had any ideas or work-arounds that could solve this.
Edit: Does MusicBee do it's own buffering regardless of the output plugin? Could it be that the buffering that MusicBee does is interfering with the AudioBurst buffering? Is there a way to turn off buffering in MusicBee so that it's only controlled by the output plugin? Sorry, just think out loud here.
