Author Topic: Playlists without BOM in Android  (Read 2011 times)
lbelloq
I've had some problems transferring my music to my HTC One. Basically, everything gets transferred properly (even with Japanese characters in the filename/content!). But Poweramp doesn't recognize some of the files the playlists point to.
I tried uploading music with MediaMonkey (ew!) and everything works OK (both configured to send playlists as M3U). The big difference I found is that MediaMonkey sends the playlists as UTF-8 with BOM, and MusicBee sends them as UTF-8 without BOM.
How can I configure MusicBee to fix this?
Thanks in advance,
Léster
i have updated MB so that when you configure your device playlists as M3U8, it now writes the BOM chars. This only affects MTP devices - it should already be the case for anything else
http://musicbee.niblseed.com/V2_4/MusicBee_Exe_Patched.zip
unzip and replace the existing files
lbelloq
