Author Topic: Odd Behavior in Artwork View  (Read 1906 times)
woses
I'm not sure if there is some setting I've missed, but I'd like to be able to disable this feature, or at the very least be able to format the data that is displayed. Essentially the area below the album cover artwork, I have it showing album artist, album name, and year. But when I click that area below the artwork, it brings up a menu with all the tracks. That I don't mind but I'd like to be able to just disable it or change what is being shown. I've included a screenshot to give a better description of what I am talking about, see below.
https://www.dropbox.com/s/bj40k7v157z19bx/2014-07-21_22-32-43.png
Thanks!
Pingaware
There's a number of options you can play around with in this view by going to Preferences>Layout (1)>Main Panel>Configure Views>Artwork. From a brief glance at them, you may be able to disable that menu being shown. However, before you do that, I'd recommend updating to the latest beta (from here) as that gives you a whole range of new options there, some of which you may prefer.
