I installed the plugin that allows discogs.
I press the CTRL+SHIFT+T and I start using diferent album name or artist but it can never found the album.
the current album title on each audio file is "Sancho Panza - Carnival"
on the discog website, I also search this album and it immediately found it:
https://www.discogs.com/Various-Sancho-Panza-Carnival/release/69342In the Album Auto-Tagger dialog box, I searched for:
Album artist: VA, Various Artist or null
Album: Sancho Panza, Sancho Panza - Carnival, Sancho, Panza, Carninal etc
and any combination of these terms or individually.
It never finds it.
Album Artist = "Sancho Panza" returns one album on musicbrain but it's the wrong one.
then if I search for Album Artist = "Sancho" (without the quotes), it founds nothing.
This is really weird, "Sancho" is part of "Sancho Panza" so it should find it.
I even tried Sancho% or 'Sancho%', but this plugin is not using SQL language.
I know the plugin works with discog as I found other albums where the result set come from discogs ("Maroon 5" for instance)
This is turning me crazy! I'd like to understand the mecanics of this search plugin.
Can someone help me?
