Author Topic: Making MusicBee sort by album (similar to Windows Media Player)  (Read 3907 times)
ElWongo2
Hey all. Forgive me, but I honestly like the way that Windows Media Player sorts albums.
I like being able to see all my albums, but not the songs to clutter up my view; and I like being able to click on the album icon to go to that album. That's all I realy need - well, that and the 'now playing' bar.
Any ideas on how to make this happen?
ma_t14
Like this?
Use the "Configure Layout" button (shown in the screenshot) and choose artwork view
What do you mean by "now playing" bar?
ElWongo2
Fantastic, this helps a whole bunch. :)
Next question; is there any way to group the albums alphabetically? Not sort, but group.
Also, what's the easiest way to merge all my compilation albums together?
https://www.dropbox.com/s/rzrmvxjgwvrphxf/Screenshot%202014-07-19%2009.00.10.png is what I'm looking at, and it's a little frustrating to see my compilation albums all split up and skewered across the cosmos. How could I fix that?
pietergdp
I'm not sure if this is what you had in mind with the alphabetical grouping, but you can have a look at it.
http://musicbee.wikia.com/wiki/Useful_Virtual_Tag_Formulas
Look under "Custom AZ bar using vertical Column Browser"
ma_t14
Care to elaborate?
I suggest you do a forum search as there was quite some discussion about this topic
Also make sure to have a look at the wiki, you will probably find answers to most of your questions there: http://musicbee.wikia.com/wiki/MusicBee_Wiki
ma_t14
Also why make two separate topics about the same thing? Just bump your previous topic with a reply if you feel that your questions have not been answered sufficiently
