Author Topic: v2.3 - Miniplayer bigger than in previous version  (Read 3008 times)
tubescreamer
is this a configuration issue or is it the case that the miniplayer view is now nearly triple as tall as before ?
I would like to get it thinner as before as I need the space on screen for other things.
Thanks
Andreas
ma_t14
It's the new default layout that has been implemented a while ago but you can still use the old one by going through:
Edit>Preferences>Layout(2)>Mini Player > Configure Panel > Use Classic Layout
tubescreamer
Thanks, but it does not work, even after restarting MusicBee :-/
ma_t14
Are you sure you changing the layout for the Mini Player and not the main player panel?
tubescreamer
Indeed, I must have done something wrong. Sorry for the false alarm and thanks !
