Author Topic: Cannot burn playlist to CD  (Read 2622 times)
gerry
When I try and burn a playlist to disc I get an error ... Burn Failed With Following Error: Access is Denied.
I've tried rewritable and non rewritable discs and both produce the same error .. any ideas?
I'm running the latest version of MusicBee on a laptop running Windows 8.1
Pingaware
By latest version do you mean the latest patch (2.4.5303)? I have a feeling that CD burning problems were fixed in the 2.4 branch sometime, but are subsequently still broken in the 2.3.
If not this, then I'm mostly out of ideas. Possibly try running the program as an administrator?
gerry
Thanks .. I've tried the administrator thing ... I'm running version 2.4.5227
Pingaware
Think it was fixed before that. Out of ideas then. Anyone else going to take a punt?
gerry
Thanks for the help ... I'll keep looking for the answer!
start by using the forum search function - its been reported and fixed in recent versions
