Author Topic: Where has left sidebar control gone?  (Read 9113 times)
Xyzzy
v2.4.5302
The small icon to show/hide left sidebar is gone. Is there something corrupt in my installation? I use the icon frequently.
Pingaware
It's the new layout. It no longer exists. You can open it quickly instead using the layout button next to the search bar, or set a hotkey or custom toolbar icon for it.
Xyzzy
Quickly? Open drop down, hunt for menu item, then for another?
Why it is not available even as an option. I don't get it....
You'll have to read this whole thread to answer that question: http://getmusicbee.com/forum/index.php?topic=13082.msg79887#new
A toolbar button will do exactly the same thing, just as easily.
Xyzzy
The problem is that it is anything but 'as easily'...
What I mean is that it's a one-click operation, either way.  Yes, you have to set it up first.
akhilsukh
How do you get rid of the left sidebar in Musicbee 3.0?
You can hide it in the layout configuration window.  Click the layout button next to the search box.
Hello akhilsukh,
You posted your question in three different topics within a couple of hours.
I removed them from the other two. Please don't do this again.
akhilsukh
I'm sorry. I tried to uncheck it but it was greyed out and i couldnt uncheck it.
akhilsukh
I still cant find a solution because unchecking the music option is impossible.
You might miss this image at the top of the page (and the tabs page needs revision), but this is what redwing means: http://vignette2.wikia.nocookie.net/musicbee/images/1/1c/Panels_Configuration.png
