Hello,
Needed to sort out my music collection, so decided on musicbee, with converting my FLACs to AAC for use with iTunes syncing to my iPhone.
Question is, I'm using the qaac encoder as I read it is generally regarded to be the best (as it directly uses Apple's own). Loading the codec in musicbee and enabling AAC, I see it provides default values. Will these also work well for qaac? I should be fine with those conversions?
Finally, I'm not exactly sure how the quality translates fro those 0-2 figures. I have been used to 256kbps AAC being used as standard for a while, so what would that translate to with the 0-2 system?
(Feel free to correct me if I don't need it, I'm an avid FLAC audiophile, so I just want the best quality/size ratio for when converting to AAC to put on my iphone, I'm a bit green around the edges when it comes to lossy formats!)
