Well, I'm not really enthousiastic about this new layout. I like the idea of merging the toolbar and the tabs bar but here the result with my usual layout:
too many "...":
I don't wanna use vetical tabs bar (same result + vertical text isn't easily readable) or horizontal in titlebar (I'm trying to get a clean layout in my skin, so titlebar have to be clean + "1 click" toolbar buttons become "2 clicks" buttons).
I was quite pleased with the old layout. Enough space for all my tabs and no icon, only text:
Tried to solve this. Let's try to
hide the tabs text and just display the icon. In fact, it's gonna be perfect: this new bar is going to display icons only.
But I forgot that almost all my tabs have the same icon (the library one).
So,
would you consider to add something like this: right click on the tab, then "choose icon" (the icon would be in the Icons folder") and hide text? So, tabs icons would look like the toolbar buttons (same space between icons and same icon size), but left aligned (toolbar icons will still be right aligned).
One last thing,
about the now playing duration. I don't get it. I would have understood if the Now Playing header had been removed. But this header is still here. So, why moving the duration so far?
vs.
