Author Topic: Where to Save Ratings  (Read 3777 times)
V4lve
Following a discussion on ratings in another thread I propose an option to choose if ratings are saved in the MB database or file tags.  Complimented by an option to save ratings in tags for specific files..
jB
I set all my music files to "Read-Only" because I don't use MusicBee as a tagger - only a music manager. Because of this, MusicBee will only save ratings to the MB db - this I know. I don't know if it already does that by default or not. If not, I agree an option to select would be nice.
If you are worried about MB messing with your tags, just set your files to "Read-Only".
MusicBee v1.2.3876
i've implemented a simple on/off preference for the next update (defaults to store in file)
