Author Topic: VST Effects Plugin  (Read 106119 times)
Joja2k
The pictures were taken prior to making any changes. I took the pictures, tried all that sveakul wrote and then posted my answer.
Please post a screenshot of your current VST settings.
i really don't understand you. 1st screenshot is pointing mb vst host plugin to "C:\VSTs" folder, and 2nd screenshot shows "C:\VST" folder.
Joja2k
The two folders have the exact same vsts in them, I just renamed them as i saw someone wrote that maybe you can try to create a whole new folder and and write the path manually, maybe it would work out.
There is ONE folder in your picture https://imgur.com/bxclPom, "C:\VST" .  The folder path you wrote in the host preferences path, according to your own picture https://imgur.com/YJRHDmF, is "C:\VSTs."  Change the name written in the box to match the name of the folder;  in other words, make BOTH of them "C:\VST".
Joja2k
Whops, my bad, thanks for pointing that out but bad news unfortunately. Still nothing  showing up in musicbee's eq section
wealstarr
@sveakul thank you for that bass_vst update. But I like my long range barrel plugged into my gun so that when I'm shooting, there's no air gab in between. Same with the VST, I don't want additional tools to be able to get around a shortcoming . I'll submit a request for 64 bit version of Music bee tomorrow, god willing.
wealstarr
@Steven
The new bass_vst freezing the plugin's state and no amount of knob tweaking and moving sliders making any change. Older one works as expected.
The newest mb_VST.dll has an inaccurate window geometry.
@Steven
Are you referring to a particular VST plugin?  Which one?  By "older one" do you mean an older version of that plugin, or bass_vst.dll?
wealstarr
No, I'm referring to bass_vst
I meant, what is the plugin you are referring to here: "..freezing the plugin's state and no amount of knob tweaking and moving sliders making any change."  I am only using two simple VSTs (LoudMax, a limiter/compressor, and Wider, a stereo expander) and their sliders move and produce changes as expected.  This is with bass_vst.dll version 2.4.1.6 (or 2.4.1.5) and the current version of mb_VST.dll from the Add-Ons section of this site.
wealstarr
Initially Hofa, but when I realized, after updating bass_vst that controls no longer respond, I tried Fabfilter too with the same result. Once I reverted to old bass_vst from 2018, everything went back to normal.
