Author Topic: Music Bee organization not working  (Read 2861 times)
It's telling you it can't locate the files.  If you look for any of those files in your library, can you play them?
Chaython
All files are playable, there may be some missing but there needs to be a way to ignore that as I have a 500GB library
The latest MusicBee patches.
Chaython
I don't even want it to resort my music I just need it to sort new songs so I can uninstall itunes
Chaython
*edit* it reorganised files in my library folder but still hasn't moved external files
http://i.imgur.com/7uPIvQt.png
tried a few things, got a couple errors read through the errors added an exception for c drive.... all fixed now :)
Now all we need is digital booklet support
Todays update fixed [part of the issues*] the issue, thanks!
Last Edit: June 05, 2014, 11:54:36 PM by Chaython
