Author Topic: [SUPPORT ADDED] show all artwork  (Read 6442 times)
  • MB Version: 3.6.8878 P
This post;
hi all
been playing about with this excellent program but as yet i havent been able to do this....
when i click on an album...it will take me to that album and display one picture..usually the album cover......is there a way to display 2 pictures..album cover and album back cover....most ,if not all , my albums i have 2 pictures and was wondering if its possible to display both at the same time.its not a big deal...was just wondering.....
got me wondering if this could be a future addition to the expanded artwork view:
with double-clicking on the large artwork opening the floating full-size artwork panel.
Last Edit: May 31, 2017, 01:00:54 AM by Bee-liever
+1
With recent enquires about displaying all album artwork, I thought I'd dredge up this long buried wishlist request.
KangNi
+1  it's an awesome idea.
In my case I've put additional album artwork pictures in many album folders (the filenames are just random). It would be great if these pictures could become presented as slideshow in the album cover view if "image rotation" is enabled.
image files with a leading "." could become ignored for example.
Greetings
Last Edit: August 09, 2017, 08:53:06 PM by KangNi
dgbx
vzell
This is done now. Its enabled in the Expanded Panel settings dialog
I can't find this dialog...can somebody post a screenshot
Select 'Customize Panel' from the header in the artwork view > Configure Expanded Panel
wobbly
iam seeing 2 small covers  (same cover) and not all artwork is showing  up  how is this ment to work ?  e file names ? or is it getting cover from tag ? or both ?
dgbx
If you right click a song you will see the tagging window open up. One of the tabs to choose is titled "Artwork". Click on that tab and you will see the artwork that is currently tagged into that file. For my songs I often have both Front Cover and Back Cover. Those are the two small covers I see in this new feature "Show All Artwork".
