Author Topic: Change now playing fields (Album and Track view) ?  (Read 2088 times)
MewCore
Hello,
is there a way to customize fields I highlighted ?
 Thank you in advance!
Pingaware
Yes. Press Ctrl+O (shortcut for preferences). Then go to Layout (1). Under the Main Panel header, click Configure Views. Then go to Album and Tracks and you can change the fields displayed there.
To jump straight to Album and Tracks settings, you can also click on the button in the header row just above the vertical scrollbar at the right of the main panel.
