Author Topic: shuffle/random keeps replaying same song (even within album)  (Read 3720 times)
fohrums
I'm on a mission to delete songs i'm done with.
Problem is it's hard to do this if MusicBee keeps playing the same songs even within the album.
ma_t14
If you right-click on the shuffle icon there are shuffle settings you can adjust
fohrums
Thank You.
These are these settings I went with and made a HUGE versatile difference as 'random' just keeps choosing the same tracks, so this solved it.
ma_t14
So if you choose the options "shuffle randomly" and "shuffle tracks individually" you are getting not so random patterns? I am not using the shuffle option personally but I believe this should not be happening.
fohrums
choosing the options "shuffle randomly" and "shuffle tracks individually" you are getting not so random patterns? I am not using the shuffle option personally but I believe this should not be happening.
Most definitely. Most notably within albums where the same song keeps getting played. I even forgot how many 'Single-releases' I have because of this. I keep getting the idea that the database just needs to be flushed?
ma_t14
What exactly do you mean by that?
fohrums
.... Most notably within albums where the same song keeps getting played....
Sure the play will shuffle between artist, title, & album. When it does randomly select between albums for different artist it will mostly select the same song when it re-visits back to that album (when shuffling).
An example is I have an album and track01 for that album keeps getting replays but the rest of the other tracks within the album are simply not being played at all.
