Author Topic: Creating Playlist Folders  (Read 3247 times)
tgilmore
I seem to be missing something???
I'm simply trying to make folders to organize playlists
but new folder option is greyed out.
Thanks for any help
Alumni
You can always create or edit playlist folders in Windows Explorer, it's just a regular folder.
Last Edit: May 14, 2014, 10:50:00 PM by Alumni
tgilmore
Where exactly would I place these folders using windows
Alumni
I think the default location can be found in Users\YourName\My Music\MusicBee\Playlists.
Restart MusicBee to reflect any changes made in Explorer.
Do you have the playlist node open in the left panel?  That's the only reason I can think that the New Playlist Folder option would be grayed out.
Just a Refresh should suffice.
A bit weird the option in MB is grayed out though.  ???
