Author Topic: PureLight BeeMetro  (Read 43177 times)
silvestreccf
You need to install the latest update: http://getmusicbee.com/forum/index.php?topic=121
This is the first step
i dont understand what you mean with: EDIT: Found it now!  Needed to use updated version listed in the forums.  The setting then appears in the config menu for the album art panel.
Very nice skin  ;D.
Excuse my newbie-ness with Musicbee, but how do you get the drop down track list of selected album?
I am able to get a permanent panel to list selected album's tracks, but not the pretty iTunes-style drop down list.
Thanks!
silvestreccf
I don't know what you mean with: EDIT: Found it now!  Needed to use updated version listed in the forums.  The setting then appears in the config menu for the album art panel.
Very nice skin  ;D.
Thanks!
Joshua
Colour problem.
If you select an item from "Library Explorer" > select an item from "Main Panel" - instead of the item you previously selected from "Library Explorer" turning light grey, it turns black.
silvestreccf
If you are talking about TABS, this problem ws fixed...try the links again, e if you can, please post a picture, I really need to see this problem.
Colour problem.
Joshua
https://imagizer.imageshack.us/v2/1600x854q50/819/g4pp.jpg
1. Click something in library explorer
2. Click something in main panel
Last Edit: June 15, 2014, 06:14:30 AM by Joshua
silvestreccf
I will fix as soon as possible, thanks for reporting.
silvestreccf
 4.1 Version - 16.06.14
* Library Explorer Collor Problems
See link in first Page.
Joshua
Pleasure. You're skin has great aesthetic but it is very unclear for "album and tracks" view.
Would you consider making a modified version? Like this:
https://imagizer.imageshack.us/v2/1207x689q90/855/zr5i.png
- PureLightBee Metro - Blue
- Borders of "Smooth Grey" skin
- Columns of "GPlay Music" skin
silvestreccf
My idea is to make it as flat as possible, even better if it were fullscreen player,
all based on Zune, the most beautiful player ever made, so I removed edges,  that gave a different aspect from the others skins .
If you want, I can  send the source files and you can create  the way you want.
Joshua
No worries :) I do not know how. I started reading through the guide in the "Developers" > "Skins" forum but took one look at one of the skin files and was like "No freakin' way man!". ;D Thanks anyways.
Last Edit: June 16, 2014, 03:31:33 AM by Joshua
coffeecup
I really like these skins and also beeNight metro, they are now my most used skins.
Great work silvestreccf
silvestreccf
Please see the new Louge Skins, make a test, they realy good and takes lots of work.
