Author Topic: Where are the online radio stations data stored, & can I copy them to another PC  (Read 1945 times)
Skoop
My list of stations and their settings.  I want to put them on a second PC without manually entering it all.
Can do?
You can right click on the Radio node and choose "Export Stations" to create a file that you can then import on another computer.
Skoop
Bravo.  Thank you.
A bug that I found with it, though.  It didn't bring over the Category field.  I use that one to name the Broadcast City.  Only one out of about 20 came over in the export/import.
