Author Topic: Which Lyrics source is best?  (Read 3624 times)
BeeBeeKing
Just wondered if anyone has found any one source to be more reliable than the others? Most of my music is Blues genre if that makes a difference.
Just That the lyrics I see often bear no resemblance to the actual lyrics  ;D
Are you using the Lyrics Reloaded plugin?
BeeBeeKing
No, just the four sources included with the program. Where do I find Lyrics reloaded  plugin?
BeeBeeKing
Well i found it here http://musicbee.wikia.com/wiki/Lyrics_Plugins but unable to intilise it -can't read beyond end of stream message comes up when I try to enable it ?
Are you recommending this plugin or not?
Yes, it offers a lot more lyrics source options therefore is more likely to find correct lyrics.  If you're having trouble with it, post in the thread for it on the forum (should be linked from the page you found).
