Author Topic: How to remove all ID tag in one shot?  (Read 3225 times)
markzzz
Is possible remove all/every tags in a file? (Tags, Tags2, Artwork, Lyrics).
In winamp was easy (just deselect ID3v1, ID3v2).
Here  I cannot find any options.
Go to Tools > Tagging Tools > Remove Tags.  Then check all tags.
Alternately, you can go into the Tag Inspector and delete all tags.
Either way will work for single or multiple files.
http://musicbee.wikia.com/wiki/Tools_Menu
http://musicbee.wikia.com/wiki/Tag_Inspector#Tag_Inspector
markzzz
That's just PERFECT! I love this software! Thank you!
