Author Topic: Copying or Moving FLAC Files  (Read 2364 times)
SnookAU
Hello There,
I noticed when setting up musicbee from scratch now you can't seem to make it 'copy' FLAC files you drag onto it into your library, it will only MOVE them.
Previously you were able to copy them.
Was this feature removed? Can an option please be added back to choose either?
Thanks
SnookAU
Latest patches (3.5/3.6)
SnookAU
Yeah have seen that, Tried that once and it didn't seem to work. How come it can't be included as a check box to enable it again (with brackets, unsupported or something).
Really useful feature when dragging music files from a NAS or something, DO NOT want them moved. Only Copied :)
did you read the topic linked to? the old functionality can be re-enabled.
Also just hold the Ctrl-key down when dragging and it should perform a copy
