Before I address this topic, I would first like to thank you Steven for your work with MusicBee. I appreciate what the program does and allows.
My main issue is with the hotkeys available (though it might be linked to "Now Playing List" behaviour). With the window open, or minimized, I cannot select a previous/next song using the hotkeys without the intermediate songs automatically playing (wanting to go from song 1 to 8 would play the first bits of songs 2 through 7). There are "Playback" hotkeys available for playing previous or next songs -- but no "Now Playing List" hotkeys for browsing up or down the playlist without playing all the songs one is browsing through.
Moreover, there are no dedicated play and pause hotkeys, only "play/pause" and "play now". While the first works as intended, "play now" seems to just play whatever album is selected in the media library part of the program. Would it be possible to include new hotkeys that add the option to simply play whatever song is selected in the "Now Playing List"?
Basically, I feel that a few new hotkeys would greatly improve mouse-less program usability:
-Now Playing List: Select previous track
-Now Playing List: Select next track
-Now Playing List: Play selection
-Playback: Pause
And a final tiny suggestion: is including the icons in /skins in the actual .exe and not in .ico files possible? I spent half an hour trying to get the Windows 7 taskbar to show the right icon in the pinned shortcut (I selected an icon in MusicBee and then pinned the program to the taskbar but the shortcut showed the .exe's default icon when closed and the new icon only when running). Turns out I had to go to the actual "AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar" shortcut to get the thing to show the proper icon both when the program is closed). Maybe a Windows issue? Kind of a stickler, yes.
Thank you for reading.
